Wanted - Fork ear washers and rubbers
I think I have what you're looking for: 1T3-23146-50-00 oil seal washer (2), 1T3-23163-51-00 gasket (4), and 1T3-23116-51-00 lower cover guide (2). These parts are numbered 15, 16 and 21 on Front Fork parts diagram fiches for models earlier than 1982; in 1982, they show as #45, 46 and 50 but with same P/N's listed above. If these are what you want, PM me. I live just north of Rochester, so you could pick them up as an option to mailing them.
Nope, I'll try again to clarify what i need.
There are rubber grommets and washers that hold the fork ears (headlight brackets) in place between the triple trees. What I'm looking for is the grommets and washers. I haven't seen a diagram of the assembly anywhere so i don't know part numbers or even proper names of the grommets and washers
Parts 14, 15, and 30
There are many websites for Yamaha parts that have easily accessible parts diagrams - powersports and boats.net, just to name two of them. I suggest that you open the parts fiche for Front Fork on one of these sites and then identify the parts you need by correct name and number - you are likely to get more responses to your request.
I have some, the metal part is chrome and kind of channel shaped the rubbers are square section.
Thanks, gggGary. It's for '79 xs650. The bottom and top are similar except the top uses a metal chrome ring The bottom rubber is the same except no ring is used. I just need the one rubber ring.
I could use a couple of the 1T3-23163-51-00 parts for my 81 650... Watcha' got, and how much.. :) (it is the one that goes under the fork ear, and has a raised inner lip, correct..?)
