nb1914
Hi all,
finally got my bile together and the holy grail of an MOT. when riding to the MOT station i noticed front end judder ( even knocking ) on front braking, not necessarily at high speed. The head bearings are solid i installed All Balls tapered bearings and there is no play at all. So i thought i would start at the simple stuff first and check fork oil by emptying and refilling. When looking at the fork top bolt i see what i believe is the dampening adjustment screw, so can you simply undo the top bolt with that screw in situ ?. in case there are any other suggestions i have put new pads in with the old discs and they havnt bedded in yet.The forks are original and most likely very tired, i think the springs are made of marshmallows as the ease of compression is surprising ( I'm not even sure if there is any oil in them )
