AussieHard
AussieHardTail
1. 40 Deg Rake.
2. 21" Front rim with standard tyre size.
3. 18" Rear rim with standard/200mm tyre size.
4. 4" Ground Clearance
5. Engine mounts in stock position.
6. 0 deg Adjustment in triple trees
7. Hidden axle plates
Stock offset distance
Need to transfer this into CAD and work it some more.
The Trail looks to be about 14" I'm estimating which I think is a concern. Any ideas on how to shorten the trail other than offset triple trees or changing the look???
What is the length of the standard swing arm and on the drawing above where would it start from…. Want to work out if my rear axle would be in the same place.
Also interested in how the extended fork inner tubes work, do they use all stock internal springs, dampeners etc??
