David M
I've seen engine stands, but I hadn't seen any frame stands around here; or just about anywhere else for that matter.
I wanted to get my frame up off the floor to a reasonable working height. I also wanted it to be stable and not wobble around because of the location of the side stand mount. Since it's only for one project, I wanted something that I could make myself and making it from plywood means that it's easy to assemble, disassemble, and recycle.
I'll use the stand for most of the assembly work up to the point of reinstalling the engine.
The base is 18" x 30" x 3/4" plywood. The bolts are 3/8" x 3.00". If it gets unstable, I'll undo a few screws and move the base back or forward. Or maybe just screw it to a longer or wider piece of plywood. If it starts getting too heavy, I'll screw some casters to the bottom.
It took all of about 2 hours to measure, cut, screw, glue and mount the frame. I screwed the front section to the base first and then bolted on the frame. Next, I bolted the rear section to the frame and got it sort of plumb & level and then screwed that to the base.
I may be just reinventing the wheel but so far, it's been a great solution for me.
