Front Wheel Swap Help
figure8
XS650 Guru
Pekin, IL
I'm trying to help someone who wants to swap to front drum brake set up. Xs front drums aren't cheap so I'm looking for alternatives. I found this rim off a Yamaha IT 175. Doing a little research it looks like this it's meant for a 15mm axle. Would swapping in the correct 17mm bearings be ok or would they be to thin to safely run?
The axle for these rims has a piece of curved rod off the end that I can only assume works as the brake stay? Yes I realize spacers would need to be made to correctly center everything up, along with fabbing up a brake stay.
Any help would be appreciated. Here's the rim in question.
http://m.ebay.com/itm/1982-YAMAHA-IT-175-OEM-FRONT-WHEEL-TIRE-BRAKE-DRUM-/121720470148?nav=SEARCH
Honestly, I don't think that's going to give you much stopping power. It's a small diameter and only a single leading shoe type. You'd probably be much better off using an XS360/400 drum. They are very similar, maybe even the same, as what came on the early 650s .....
http://www.ebay.com/itm/Yamaha-XS40...ash=item46431e974f:g:eNEAAOSwPcVV2jeB&vxp=mtr
All these brakes use a cleat on the fork lower to anchor the brake plate. That would involve aluminum welding one on a lower or buying a bolt-on one like this .....
http://www.motolanna.com/ourshop/pr...ront-CNC-Billet-Alloy-Yamaha-SR500-SR400.html
Hi figure8,
make 15mm to 17mm adapter bushings for that wheel's original axle and use a T-bolt clamp to hold a bracket onto the fork lower for the brake stay.
Mind you, that wheel would only be good as a rule-cheater to stop your buddy getting a ticket; as a brake, it'd be kinda pathetic.
I'm with 5twins, your buddy needs to find a better class of drum brake than that one.
I bought that motolanna adapter for a 71 drum put on a 1980. it does work, its a good piece. with careful grinding filing, looks good. Bolts right on to the caliper bolt holes on the forks. A bit steep in price, $60 from Thailand, but its the only adapter out there.
Heres my thread on the adapter, first page.
http://www.xs650.com/forum/showthread.php?t=42278
