MadRat 88
I'm having trouble getting my 81' dialed in. I'm running open pipes, 45 pilot, 142.5 mains, new XS performance ignition coil and stock TCI. I have adjusted valves, checked timing, changed TCIs, switched plug wires and I keep getting the same response out of my rig. I don't have any guages on the bike so I'm not sure at what rpm the problem occurs, but my problem is somewhere above mid range and into upper/high rpms the bike starts to shake and jerk and will not get over 55-60 mph.
I thought it was an ignition issue and have been testing/replacing parts with no luck.
When I read the plugs, the right side is a light brown and the left is black and sooty with a hint of oil. I haven't done a compression check since the day I brought this basket case home but I'll be heading to Sears this morning when they open. I have been on the forum since 4am reading about testing compression and trying to isolate the problem.
I seem to run fine all the way up to about 3/4 throttle, the bike then starts bucking and I have to let off the throttle and find a "happy" spot where the bike is not shanking, unfortunately a top speed of 60mph isn't all the "happy" to me.
Sorry for the long wind, just trying to put out as much as I can and get this thing ripping!
