Yes, 1/4" will fit but if you are doing a stock set-up and want to re-use those protection springs (recommended), they won't fit on the larger O.D. generic 1/4" auto line. I highly recommend the line MikesXS sells. It's the same as the original. I also recommend their breather line. Again, thin wall and the same as the original so you can re-use those protection springs.
