plattey
Hi guys, so normally a fuel pump wouldn't apply to a stock xs650, but the bike is turbo'd and needs a pressurized fuel system to support the pressurized intake air.
I installed a solenoid style fuel pump that is external to the fuel tank. It has lasted about 400 miles worth of running and has rolled over and died. It stopped on me last week and I tapped it with a screwdriver and that got it pumping again. The fuel pump stopped working again today, it didn't even fizzle or smoke (grounds, switch, connections and fuse all checked good). The screwdriver trick didn't work this time. I checked the resistance of the fuel pump coil and it was on the scale of 187K ohms. When I talked to the napa peeps concerning finding a replacement pump with the specs I needed (15-20psi), they mentioned that solenoid type pumps vs vane type pumps are less reliable. I would like to agree with this since the solenoid style pump is relying on a coil and magnetic field to accelerate a cylinder back and forth with some check valves in the system, while the vane style is at a constant rotational speed (less vibration with respect to the solenoid type). I would like to get some feedback from a larger audience than just the parts guy at napa. Has anyone encountered this theory personally? Thanks!
