Howdy Howry, No I do mean 20mm axle size, not rim width. The offset kit is expencive but just the sprocket is not, I just can't remember where I seen it? Making one out of two would be easy I don't think it would be hard to do Top axle is xs and bottom is gsf1200, both fit each others wheel bearings perfect! They are the same diameter as is the DL1000 Vstrom axle. I have all three wheels and axles here and they are all interchangable.you mean 200mm right? and how would i be certain that it would work? and yeah ive seen the offset, kinda expensive to buy - soo maybe ill find a way to make one thanks for the reply scott...
I just looked up axle size for gsxr and it is 28mm, so no the xs axle won't work on that rim. Like I said earlier I did not know bearing size for gsxr but I do nowsoooo, are you saying that it should fit the xs650 axle? i have 2 of em, from 77 xs650d and from from 72 xs2.
