np at all . i think when you hardtail the swingarm make sure your angle is correct so when you weld the 1/4 plate from the frame to the swingarm it has the same stance as if it still had shocks follow the same steps as if you were hardtailing a shaft drive frame. a lot of guys there just weld to the swingarm on the right side and and use the new tubing to bolt where the shock mounts go.if you raise or lower the swingarm to much your chain will not fit properly. as for feeding the chain that is the same as if it were shock or rigid. remember the swingarm stance is the same per say it just becomes a hardtail with a drop seat type feel the seat is approx 22" off the ground. the other thing is the front end is stock 34mm with 6" over tubes. so i take it this one passes
