I've got a freshly rebuilt top end. I have run through a series of torques and break ins. I replaced the 4 outer washers with thicker copper washers. The inners are still steel. I checked the compression recently and was getting 120 left, 140 right, so I decided to do another torque and valve job. As I'm torquing the acorns to 30ftlbs, It seems half of them (some copper, some steel washers) are loose every single cycle. Sometimes up to 1/2 turn before it clicks. That torque wrench should click right away every time. Any idea what's going on?
On one of them, as I was slowly torquing, it got REALLY loose and I thought for sure I stripped the threads. I decided to take the nut off and look, didn't see anything. I tightened it back up and it seemed to hold torque. Went around another sequence and it's slightly loose again.
I was reading somewhere not to put the acorns on dry threads, which I'm pretty sure i did. Could this be the problem? And how safe would it be to loosen each nut, one at a time,and put some grease or anti seaze on the threads... think that would solve it and not compromise my head gasket??
thanks for listening to my slight freakout.
