- before drilling everything out you may like to try using a brake booster check valve in the breather line, creates a negative pressure in the crankcase which has the effect of sucking the seals into the case and helps hold oil leaks...
Could this (Ref No 15) if fitted incorrectly course a pressure problem but Im shore it in right.
