CalsXS2
XS650 Guru
- Messages
- 1,006
- Reaction score
- 52
- Points
- 48
So I got me a Harbor Freight parts washer. I went to Tractor Supply and got the TSC-1000 petroleum based solution that I had read so much about. Well I gotta tell ya. I was not impressed. Especially for the $80 I spent for it. I wanted a miracle. On top of that, my pump worked 1 night with that stuff then it locked up. I can't say for sure that the TSC-1000 locked the pump, but you know you're not supposed to run petroleum based cleaners through these cheap parts washers. All I know is it wouldn't pump the next day. I thought maybe there was a piece of crud in there so I tore it apart. That thing was locked up solid.
So I'm bitchin and moanin about this parts washer not being worth a crap. Then my Son tells me he just cleaned a set of really nasty carbs with Purple Power. And they turned out great.
I know all about the fact that some of those cleaners doesn't play well with aluminum. But I think the trick is not to leave it in there too long. My Sons carbs had no ill effects.
So I filled the tank with 2 gallons of Purple Power and 7 gallons of water. I put a rear drum in there that had caked on grease around the sprocket that the TSC-1000 would not remove. Even after soaking a week. I let it soak about 1/2 hour. Pulled it out and hit it with a brush and the stuff came right off.
In the middle of all this I decided to try some heat. After all, you don't wash dishes in cold water.
I went to Home Depot and got me a 2,000 watt, 120 volt water heater element and a thermostat. Did the install and some custom wiring. Heck. I even put a pretty light on it so I would know it was on.
I rotated the sprocket to a side I had not yet done. Turned the heat on and once up to temp (135*), I let it soak about 1/2 hour again. When I pulled it out I seen something running down the side. I thought I melted the the aluminum. But to my surprise it was the caked on grease.
I guess this mod isn't for everyone. But I'm tickled to death with it. If anyone want's specifics, just ask. I'm also open to criticism. Do you see any concerns, or areas for improvement. Lets hear it.
Oh ya. How hot should I run it. How hot does a dish washer get. You guys see any problems with getting my parts that hot.
Here was the hardest part. Bringing myself to drill a big ass hole in my brand new parts washer.
I decided to put the heating element here. I was going to put it on the front, inline with the pump, but I didn't want any electric stuff in the way.
For safety I built a wire cage around the element. Now I can sit a part on top of the cage if I need to. And if I get a really long part I can sit it diagonally across the tank.
A look at the back side.
I Shoe Gooed some plastic boxs on the back to enclose the electrical. Just a rough in here.
Firing it up.
https://www.youtube.com/edit?o=U&video_id=Kdvnc5feeOI
Starting to get warm.
Starting to cook.
Cooking at 135*
Please let me know what you think.
I do not recommend doing this with a petroleum based solution. Do your own research.
Firing it up.
Starting to cook.
Cooking at 135*
