wherearewe
Rub on Ya Titties
Ez guys
After doing some work under the left side cover, one of the threads partially collapsed. I use a torque wrench with a little anti-seize to 6ft/lbs so I'm not over tightening. The PO did however run a shorter 15mm bolt than the normal 22mm bolt for god knows how long in that one thread. Well that was what was installed at least when i got it. This combined with age must have strained the thread because it collapsed to that about depth, the rest is fine.
So after tapping and cleaning out the swarf i can still use the correct 22mm M6 bolt, its not ideal but it holds.
My question is, should i drill and tap the whole lot and fit a 15mm helicoil insert? Or just drill and tap to 7mm or so (the depth of the damaged area) and install a shorter 6mm helicoil? Is it likely the threads won't line up? Or should i just leave it and say 'whatever its still good' I havnt ever had much need to use helicoils to be perfectly honest.
Thanks
Thanks
