mrkelvinator
Hey Guys,
Firstly I'd like to that every one who has responded to my previous newb posts, it has been a real help
So I've got a 1979 XS650 (Special?) with Mikuni VM34 Carbs - i believe thats the only modification done to it. And here it is on charge
The problem:
Before i start messing around with the carbs (which have been cleaned). The bikes starts on choke with some throttle and revs if i continue to open the throttle. However without throttle it wont start or will die after starting. It will not start without choke - with or without throttle.
My guess is that its not getting enough fuel hence the choke and the idle needs to be adjusted...what do you guys think?
I have the manuals that have been suggested in other posts, but just wanna know what the problem is before making any changes.
The exhausts are stock, but I believe that the previous owner has drilled holes in them...the two yellow things are cork plugs, the hole on the top is without one. Is this normal??...
Thanks for all your help
And here are the carbs:
The problem:
