I understand and have done the same often. But..... By the time you are done nickel and diming the ignition; points, condensers, coils, wires you will have the cost of a Pamco and still have an old marginal points system.
Unasked advice? don't replace the advance yet, the timing range can be tightened by hammering the "bulbs" flat and carefully fitting to the slots, and adjusted by shortening springs if needed and bending the tangs on the backing plate in. I think it's retiredgentleman that has a how to on hammer/fitting the bulbs. This part from mikes is a reproduction not an OEM part, you may not be ahead on quality. AFAIK the slots on the plate do not wear significantly.
