dstroy12
Apprentice
Everything was fine with my Chopper XS650, then I sold it. Then 2 wks later the left cylinder will not fire.
Things Ive done and checked:
Switched Spark Plug cables, left side still wont fire. Right is strong.
Removed carb, checked and cleaned left side.
Checked voltage at the posts going into coil. 12.36 to 13
Ive noticed if I really give it throttle, the left side starts to fire. but as soon as I let it goto idle, it stops. Air is coming out of exhaust, but is not hot at all.
also, at one point the left side was poping, and misfiring/backfiring. I thought it was a vacuum leak or something... I tried the Carb cleaner trick but then realizied there isnt any ignition in the cylinder to tell if there is a leak.
Im totally lost
Help!
Thanks a ton guys!
Im totally lost
Help!
Thanks a ton guys!
