I have a crank wheel that the threaded end where the alternator lock nut sits is bent.
The easy fix would be to get another wheel, but this is a 533 crank which are pretty scarce here in NZ and the crank has been rebuilt, welded and runs very true.
It does not need to be 100% as it will be running a lightened non charging rotor just to trigger the ignition.
My initial thought is to leave it and see if it runs ok, but I would like to resolve the problem.
I am open to any ideas on how to straighten it.
