wallywheels
"savage"
So I will start off this XS 1981 was built by me and my brother in 1 weeks time from stock to this I did the build for 1800.00. Ok to the point I did not know if the bike ran when I disassembled but upon reassembly it fired up great after some minor repair work to electrical and with aftermarket carb as you can see. BUT after I put the final "somewhat custom" assembled exhaust on (not the mock up exhaust as I had the first time it ran good) it decided to not run very well and oil was squirting out of the open valve covers like crazy only on the right side. Me jumping to conclusions decided a valve was stuck on the exhaust and that it was a fluke it ran well in mock up. So after some tinkering off came the head and a rebuilt top end coming up with no issues accept light rust on piston rings. Restarted bike and same thing!! I was pi$$ed so I slept on the issue coming up with I still had a bad valve, or worse, or the exhaust was not allowing air through. Well after hours of searching I found what you see below I have never seen anything like it. The inner pipe looks rusty but it is not like tissue paper it is still solid steel but only the inside pipe. This was the issue but I still cannot figure out how this happened. Heat had to have played a factor as the steel would not even bend with heavy screw drivers trying to pry it back in place. To remove it I cut the pipe in three places and slid this thing out anyhow problem fixed runs like a top now!
