john650
retired mathsteacher..yay
I have rebuilt my engine with new Heiden barrels, pistons and high performance camshaft kit. Not because I wanted more power, but because they were the only new parts available.
I am in new territory here, as I have only worked with standard engines (not even XS650 engines) in the past.
I assume higher lift/longer duration cams will increase the volume of air/fuel, and compression ratio, but I have not changed the standard carbs.
My question is this: is it safe to start this engine with standard carbs, or will the engine run horribly lean and cause damage ?
What is the minimum that I need to do to the carbs in order to proceed safely?
I am quite prepared to buy new carbs, but I would like to know that the rebuilt engine is ok before shelling out more cash.
Hope someone can give advice on this.
