Determined
XS650 New Member
Hey all. First post.
1st gear wheel in my 1979 XS Special had a worn out bushing. Found NOS one on eBay with same part #. AFAICT all the dimensions and teeth profile are the same. Only difference is the extra hole in the gear. Can't see it causing a problem. Curious as to it's function though.
Also wondering if it is common for the bushing to fail? Besides being loose from the gearwheel it was 3.5mm narrower than the gear. Oddly everything seemed solid enough before disassembly to install tall 5th gear set. Then the bushing fell out and had crazy slop on reassembly.
