well had an unfortunate incident with my 78SE. lost the right piston on the highway on tuesday night. (see main thread here) In a nutshell, holed right side piston on the highway, suspect over advanced ignition timing for the issue. I'd like to get some advice as to the best and least expensive way to fix a holed piston. I'll make sure the left side is OK, but it had 140psi when i did a compression test on it after the incident so here's hoping that that side is ok.
I was thinking of doing a quick and dirty piston replacement using a used or NOS piston and the rings off of the old piston. for the cost of gaskets and a piston (around $100) i could potentially be back up and running. Is there anything that would logically make this an ill-advised repair method?
As much as i'd like to do the Mikes piston/jug kit, $500 is a bit beyond the budget...
