birdog4549
81 XS-H Special II
I have cleaned the carbs and reassembled. When I manually raise the right slide and cover the top wide hole it slows down but no where near what the left slide slows down when I raise it and choke the top hole. the left slide is different than the right and I know it should slow down but can there be any difference in the rate of drop between slides? I suppose I know the answer so if this is bad where is the best place to get the rubber things that are on the tops of the slides. I have seen them around and I like 650 Central so far but is there any "top" place to get these things?
