pickledbabies
APOLLYON
Hello friends,I have a 77 xs with a single pole terminal in the rear drum.I have had no luck getting this thing to work.I tried wiring a relay. No Dice. I've included pictures of the brake hub terminal and the original single-wire brake switch. Any suggestions? All the other ones I've seen are two-wire switches with the spring. Should I just switch to that type? WTF.. Thanks
