Before reading on these were unscientific tests, done on different days, weather conditions, the dyno was not calibrated and I expect slightly optimistic.
We did the before and after test more out of curiosity and for carb tuning than anything else.
Test 1:
A 750 with 10:1 compression standard head VM 36mm carbs tuned exhaust and Webb 59A cam. Best pull 58 HP.
Test 2:
A full on race 750cc motor. Best pull 77 HP.
So from a 750cc motor with a milder cam and stock head you will hopefully be in the mid 50’s, a full blown race 750 70 plus HP.
The key to making reasonably good power is the head.
I have read that these old girls will hold together to about 73HP above that they start to become grenades.
If you want to build an XS the modification guide from 650 Central is a good place to start.
In the UK Smed Speed would be worth talking to,
