WOLFHAWK
I have an '81 XS 650S
No idea what previous owner did but it would't run at all
Tore it apart
Fingers crossed...
Installed:
Pamco Ignition
Hugh's PMA swap
Mikes XS Pod filters #15-0035
http://www.mikesxs.net/product/15-0035.html
Exhaust is 2-1 no muffler
I've read the carb bible at least 4 times
www.amckayltd.com/carbguide.pdf
ANYWAY
I can get the bike to start (kick only-by choice)
And it will idle fine, not perfect, but I will fine tune it via the "dead cylinder" method
Bike had no/poor throttle response, carbs leaked gas back out through the filters
Disassembled the carbs (for what seemed like the 7th time)
I have replaced:
floats
http://www.mikesxs.net/product/20-6502.html
float needles
http://www.mikesxs.net/product/48-5014.html
and the seals as well
new rubber passage plugs
http://www.mikesxs.net/product/48-5002.html
took everythinig apart and cleaned multiple times
I had put in a #140 main jet
http://www.mikesxs.net/product/48-0121.html
Mikes XS 5IX11 needle
http://www.mikesxs.net/product/48-0663.html
did not see the note about the matching needle jets nor read about them until after the fact, so those are on the way
also installed #47.5 Pilot Jet
http://www.mikesxs.net/product/48-0608.html
still very poor throttle response
I know these carbs supposedly ran lean as it was stock, so by opening up the exhaust and switching to pod filters, the stock lean jetting isn't going to cut it. that's why I upped the jetting.
I've gone through and read other members testomonials/ threads/ trial and errors/ headaches and burdens
I put the bike back to a stock main jet #132.5 stock pilot jet, stock needle, hoping I would at least have a solid throttle response at least to start with
wrong.
It seems to be ok from idle -> 1/4 throttle
anything above that it seems like it gets bogged down (so I believed it was running too rich and the gas was drowning it)
however I pulled the plugs and the weren't soaked with gas, nor was the exhaust giving out black smoke
so then I figure maybe it is running too lean?
with the filters off, it seems that gas is kind of spitting about like when little kids perform a "raspberry"
I assume this could be due to an influx of air:fuel and the air overpowering it sending the gas all over?
the mixture screws are set at 3 turns out
floats are at about 22mm
still has the same throttle issue, poor response above 1/4 turn -> WOT whether easy or hard on it
the fuel also seems to come back out of the carbs via possibly the Main Air Jet from time to time
Any clue why that is? All passages were cleaned with solvent and blown clear with compressed air...
Thanks, there's warm weather here in upstate NY and this is preventing me from enjoying it.
If it matters.......... stock tank, single vacuum petcock, choke works as well as it should
I'm hoping that when I get the matching needle jet for the 5IX11 needle, it will richen the mixture and solve my throttle problem.
Tore it apart
Fingers crossed...
Installed:
Pamco Ignition
Hugh's PMA swap
ANYWAY
I have replaced:
floats
float needles
wrong.
