I have a 1979 SF that was running quite well until I parked it a few years ago. It was stored in a shed all that time.
The cylinders and top end of the engine are original SF. The bottom end from the connecting rods down is from an SG (1/4 miles of original engine). I kept the top end of the engine because I had just had the cylinders bored to first oversize (new pistons and rings) and had the valves lapped. Engine still has points ignition.
When I turn the key on, the check light is off, neutral light is on. Alternator passes slap test. When I put the front brakes on the rear brake light comes on. When I put rear brakes on, the brake light does not come on. No rear tail light. Signal lights work fine. Horn works fine.
From there it goes downhill as I have no rear tail light and no spark. Starter does not work.
I took the kill switch apart and found the internal components had broken due to age so I installed a new kill switch. It seems to work fine as the check light comes on when I turn the switch off and goes out when I turn the switch on.
I eliminated grounding issues as much as possible by routing every ground wire directly to the battery. The ground cable from the battery is still connected to the frame at the factory connection.
I replaced all of the original glass fuse holders with new blade fuse holders. I took apart every connection in the wiring harness and replaced connectors that appeared to be corroded. I cleaned the rest with contact cleaner and sandpaper.
I've spent three hours a day for the last two weeks trying to isolate the problem but I'm getting nowhere and extremely frustrated.
The bike is on the center stand but to my knowledge there isn't a kill switch on the stand - is there?
If I connect power directly to the brake and running elements in the tail light, they work fine. Battery is new last week and fully charged.
Any ideas?
Wayne
Any ideas?
Wayne
