smg65
I installed "Superbike" bars this afternoon. They are a little shorter and a little more narrow than stock. I played around with the cable routing for quite a while. And though there doesn't appear to be any kinking and the throttle works smoothly, I don't think it's a good setup. The clutch isn't quite as smooth now, and there's a nasty bend in the master cylinder line. I did a search and didn't find much that would explain in detail how to reroute. Or perhaps I should have new cables made up. I'm guessing I will need a shorter master cylinder line. My bike is a 76. The throttle cable exits the left of the frame, and the clutch exits the right. Do I need to remove the tank to rearrange those cables? You can really see the master cylinder line bend in the picture below. Braking isn't affected, but it doesn't look right. Any tips are greatly appreciated. Thanks!!
