Is it 40 degrees from TDC to full advance?
AllanCaveNZ
Melbourne, Australia
Short question for the well learned around here - is it 15 degrees from TDC to fire and then 25 degrees from fire to full advance? (40 degrees from TDC to full advance?)
Installing a new tri-spark ignition on my 277 rephrase project and TDC wasn’t marked when the PMA was installed. The ignition is set at full advance when it’s installed so wanted to double check what those degrees to set it at was.
Thanks for the help!
The full advance changed with some models.
Later ones were 40 degrees, have a look at this thread in the tech section.
https://www.xs650.com/threads/tci-timing-tweak.55209/
35 Degrees could be called the sweet spot for these motors.
Thanks Signal. Great thread. What part of New Zealand are you in? I'm based in Mangawhai, north of Auckland a little. Will try update my details so it doesn't say Melbourne any more.
