Spent time in the garage with a quick and dirty wiring job today to get the bike running again (just in case). Choke on, electric start pressed it took a little bit but she got going, but something seemed..off. She danced, but not in the jazzy nature as usual. I clicked the choke down half way. Right off. Ok. Restart and go through the procedure again. Won’t run without choke. Get her going again and Check right side exhaust, oh ya shes hot, left side, cold. Great. Pulled the plugs, left side bone dry. Right side sooted up like a coal miner. Awesome. I wanted to change the jetting in my carbs anyways so I guess it’s time to take ‘‘em down and check them yet again. I am really bad at setting the float level so will work on that first. I wanted to go up on the pilot circuit one size(currently at 42.5). Going to read through my carb guide again. Also checked my coil. It’s the mikes dial output coil. Got 2.6 ohms between where the spade connections go and ~14k between the plug prongs. Does this seem low? Here’s a pic of my specs I keep in my book
