littlebill31
Smells of Raw Fuel
Ya, bulk is good. I tore a few taking the intake valve covers off.
you might want to a: hold the throttle a bit up while still on choke, then turn off choke, with the bike still idling high, and turn the idle screw in to that point. After the engine warms up, turn down the idle to 1200.
(this was actually before i read the whole thread)
So is it running okay now?
Aftermarket pipes will turn colors many times even if the jetting is right because they're single wall. They should, however, turn the same color. Gold comes 1st, then blue, so your blue side is running hotter than your gold side. The way your idle is high and racing all around, it sounds like you may have an air leak on that hotter side.
Yes, carb holder or maybe the vacuum barb on it. Butterfly shaft seals can also suck air if they're bad. On my original manifolds, one of the vacuum barbs came loose and you could pull it right out.
