MN_Bobber
79 XS650 Newb
If I understand the manner in which an aftermarket kill switch should work, the power comes through the fuse block, up the wire into the kill switch then down into the coil. When you turn on the kill switch, you interupt the circuit and therefor the coil loses power and cuts out the motor. Is this right?
Second - the aftermarket kill switch I got has small wiring coming out of it, maybe 20 gauge, is this substantial enough to carry the load without overheating?
Thanks everyone!
Sean
Thanks everyone!
Sean
