coughing skunk
Finally got my bike running after a winter rebuild a few weeks ago and now I've been battling fuel delivery issues.
I originally used electrolysis to get rid of all the rust in the tank, which it did, but it turned up some unexpected surprises as well. After the electrolysis I cleaned the tank out and filled it back up with gas, cleaned the carbs and went for a ride. Man what a great dat a motor with good compression can create. Never felt this motor run so strong and fast! Then about 30 minutes into riding my carbs started to pop like I wasn't getting any gas, so I limped my bike home and went to work again. I pulled the carbs and sure enough there was some odd discoloration in the gas in the bowls. I drained the tank and pulled the petcocks only to find large, as is kitkat bar size, pieces of mineral deposits clunking around in my tank and sludge in the petcocks!
At that point I decided to clean the tank and petcocks and line my tank with Red-Kote. Fast forward to yesterday when I finally put it all back together after letting the Red-Kote cure for 4 days. I kicked it over and it started just fine on the first kick and after warming up it revved like it should. I was all excited and went to go for a ride only to find that as I pulled out of my driveway the bike almost stalled. I feathered the clutch to get the bike rolling and was able to get down the road, but the engine would not rev over ~3k (no tach on the bike) and had essentially no power. Mind you this was running last week like a champ before the carbs got clogged.
I checked and rechecked the following:
-Timing - set, and re set. I've been timing my PAMCO with a light. Adjusted the advance unit so it was advancing correctly.
-Battery - swapped my micro battery for a full size, known good battery. My PMA is charging correctly as I've got 13 V at idle and ~14.3 on revs.
-Carbs - no blockages in jets, running the same tune that ran last year and earlier this year. Dies with choke pulled, even on a cold start on a warm day.
Talked to my pop about it and he suggested replacing the inline fuel filters. So I'm going to pick some more up on the way home from work today and try that. I also just ordered two rebuild kits for my petcocks as one side has a slight leak when in the off position.
Anyone have any other suggestions?
