rshelbert
81 xs running VM34 carbs. Have adjusted valves, chain and new oil. Synced the carbs as close as I can get them.
The bike starts easily, idles fine, although the right side seems a bit lean at idle as it has a slight pop until it warms up. Once it warms up it idles fine. It rolls on throttle with no hesitation or lingering.
The floats are set about 24 mm. And despite the boots being the stock bs34 ones I cannot get any indication they are leaking with starting fluid or pen oil.
The jets are as recommended in the guide.
180 mains
22.5 pilots
159 p6 needle jet
6F9 needle in 3rd groove
Air jets removed.
The left cylinder mix screw is about 1 1/2 turns out, the right is about 1
The problem is I am unsure what to change next to correct a lean mid range plug chop (about 45 mph roughly 2500-3000 rpm range. There is hardly any smoke ring in the right plug. The left has little more of a ring but both are pretty light.
All that background to finally get to my question, Should I raise the needle or up the pilot for these symptoms?
180 mains
22.5 pilots
159 p6 needle jet
Air jets removed.
