Log Splitter Seals
YamadudeXS650C
Central New York XS650
Syracuse NY
I split my logs with a Harbor Freight 10 ton manual hydraulic splitter which I welded to a hand cart to make it portable.
The seals are leaking, which is common in this machine whether you get it at HF or Home Depot under another name, and parts aren't available.
I'm focusing today on the "pumper" seals in this mechanism:
The o-rings on the plunger are straight-forward to replace:
However, these below are bunged up. I'm thinking that the only purpose they serve is to stabilize the plunger in the bore (?), not to actually do any significant sealing.
Since they seem to be unique to this machine, my thought is to fit an o-ring into the slot where they are positioned.
Opinions?
Did work some with hydraulic cylinders for excavators
At the piston inside there is seals for the + outward and - inward motion
But the seal in itself cannot take lateral movement so there is usually some type of bushing of some type
plastic material as a bearing keeping the piston centered in the bore
The same at the outgoing end
The seal has to be protected from sideways motion 2 is the bushing and 3 the seal
There are standards for cylinders so there is a fair chance parts are obtainable.
The bushing can also be OK and the seal gone.
In the best of worlds Harbor freight can have parts.
The man who can figure out how to prevent leaking hydraulic cylinders will be a rich man pretty quick
Got another question: Are hydraulic o-rings made with a specialized rubber, or can I use o-rings that I find at Home Depot or my local hardware store?
The rubber has to be compatible with the oil you're using. If you're using a petroleum based hyd fluid, you want seals made from nitrile (Buna-N) or HNBR.
Sometimes they'll state they are petroleum compatible.
Buna-N...that's the one I was trying to remember. Thanks for the clarification Jim.
This morning I discovered that repair kits are available from China for a few dollars, but I'm still searching for one for the 10 ton jack.
For something that works at basically room temperature I would say Buna-N would be more than adequate. Viton might be almost over kill.
One place local that at least when I was still working that was pretty good for things like that is:
https://www.yelp.com/biz/nu-way-hydraulic-sales-and-services-east-syracuse-2
Thanks Ken, I called Nu Way Hydraulics; they said they might be able to help me out. I'm going there tomorrow. I'll report what happens.
The o-ring sizes are unusual, and aren't found in the assortments offered by Harbor Fright.
View attachment 230798 View attachment 230799
Opinions?
I need some of the dust protectors.
Any ideas?
Thanks, Mike in Detroit. Mikerudko@yahoo.com
Any ideas?
Mike, my local supply place I mentioned actually had to special order the "odd size" O-rings, and as for the wipers, I decided to keep my old ones cuz the hydraulic specialists said they weren't at all critical to the mechanism.
Opinions?
Hey guys I got the 10 ton splitter. You all have the jack seal kit? Mike in Detroit .
I was looking at the manual that has a schematic of all of the parts. It seems that the only thing that may be leaking is that little O ring that fits in a groove around the shaft? At least the one in your picture. Don't know if any other seal could be the cause of the leak. It's the high pressure side that leaks.
