hugh, considering this mod for your new digger?
a question: you don't need to do any truing when welding the initial center pin? seems like truing would need to occur?
The centre pin between the 2 cranks..?? Its splined - once pressed together thats it, it does check to see if the main shaft between the 2 cranks is not bent from some idiot attempting to press it apart/together previously.
If you do a search on Hughs crank rephasing write up he goes through the assembly process thoroughly.
