Mischief
Looking for a starting point on this bike I am trying to help someone out with.
76 XS650
Completely Stock
Came to me in pieces. Everything back together.
There are going to be numerous issues but I am wanting to start on the basics. I have reviewed and hooked up all wiring following provide diagrams in tech forum.
I am not able to get the starter to engage using the switch. I can use jumpers to starters and I can jump the solinoid getting the starter to engage.
I disconnected the ground wire from the trees and ran a temp from the frame motor mount to the handle bar clamp.
I have gone through left and right housings cleaning up contact areas to ensure ground.
Ignition switch is new.
Single fuse system that has been temp removed and jumpered with a solid wire.
The only thing I get when the start button is pushed is the brake lining switch light comes on. Will that prevent it from starting if the diode is bad.
At a loss on this one. I have spent hours tracing and hours reviewing info on the forum but I am at a loss.
If it were my bike, all would come out and wiring simplified but not an option with this one at this point.
Any thoughts?
76 XS650
Completely Stock
Any thoughts?
