crashcourse
So I think this problem has been developing, or it could be a couple different problems. It started on the freeway at about seventy miles an hour. The engine lost power and felt like it was running out of gas, but then gained power back, and went back and forth. It felt like when you are bad at water skiing and you pull too hard on the rope and then relax, so you get jerked forward and then are left behind. That lasted about forty miles, until I got to where I was going, but it let up some towards the end. For the trip back I but some carb cleaner in with a fresh tank of gasoline and it ran smoothly the 120 miles home. That was early last week. I had run a few errands around town since then with no problems, so I thought the cleaner had done the job. But yesterday on a short hop across town it didn't start right away, then died at idle before I got out of the garage, and at a stoplight. As long as I kept the rpms high it would stay going, but even at 15 miles an hour if I went to second gear the engine would die. I'm now pretty good at clutch starting a motorcycle. It was the same on the trip home. The battery has a charge, the spark plug gap is only a little wide but otherwise they are clean.
I've had this bike (1981 Special) for over a year and have never had the carbs apart to clean them. If I had to guess I would say it's just gummed up. Any suggestions? Am I missing something obvious? Any estimate on how long it will take a first timer to take apart and rebuild his carbs?
