bryand46
I bought a 78 xs650 a few months ago and recently ran in to some issues.
First, after trying to kickstart it several times with a battery that was a bit low in charge, I hooked up a charger and it started right up. Problem identified there... So, today I was kickstarting it while the battery charger was hooked up and could not get her to start. Actually I did get her to start, just not keep running. I probably should have stopped, but I couldn't let it go and upon my last kick a loup pop came from the left side of the engine and I noticed quite a bit of white smoke coming from under the left side or the engine. Basically right where the left foot controls are but behind.
I stopped after this and jumped on these forums and did see something posted that seemed very close to what happened here. But I just wanted to be sure that this is just from the carbs needing to be cleaned and that it was a detenation from the intake valve? And if this is the case, did this do any damage to my motor, and can anyone offer a little more insight in to this whole issue? I have had quite a bit of popping on the left side since I've owned the bike. Because I haven't riden it much, I haven't looked in to fixing yet. Besides I'd rather do it myself if I can.
Thanks!
Thanks!
