kidmerc
livin in"XS"
Hey all. I read the previous posts on adjusting your clutch. My bike was having a hard time finding neutral once warm and stopped at a light and sometimes didnt want to shift into 4th or 5th gear. Upon reading the step by step in the post I went out to adjust my clutch cable. (I reread it today after adjusting last night and realized that farther down in the post it says to loosen the cable at the lever first, i failed to do that). So tonight I went out and I loosened the cable at the lever on the handle bar and then removed the small cover to reveal the 12mm nut and philips head screw. I placed a 12mm box end wrench onto the nut and tried to loosen when I noticed that A.) it wouldnt turn and B.) the whole assembly shifted to the left as I tried to loosen it. I am guessing that something inside the assembly behind that nylon washer is broken and not holding the rod in place for me to loosen the nut? Is this something that can be harmful? I rode the bike today and it seemed to shift fine. Definitely better than before I botched the adjustment. Now I am afraid that if I ride tomorrow I will break a cable or worse on the way to work.
