lowliferat
certified hack
i've got a set of mags on my sled now cause the tires are good, drum rear that when i hit the rear brake the brake stays on unless i roll backwards a bit to unlock it? this started a while ago, and i took the rear wheel off and had to beat the axle out to get to the drum, and the bearing came out with it, so i greased it all up good and threw it back togather. i asked up here about it and it was said i messed bearing up, so i figured i would run it until it started to make noise. i just went to the store for a beer in 34 degree weather and it started to do it again. i heard that the drum rear mag was an oddball year ? i have a press , so should i push bearing out? to get at brake again ? or will a spoke drum fit in there? or just trade mags for some spokes and call it a day? thanks all [/U]
