Yes, it's in that hole, actually mounted in the float bowl bottom - from the bottom. It's not screwed into the main carb body like the BS34s and most other carbs. If you can't get it loose through the drain bolt hole, bowls still mounted, you can just remove the whole bowl and try. The jet will be coming off with the bowl. It's easier just dropping the bowls than pulling the carb set.
