jkocr2
So I built the homemade manometer but it doesn't appear to be working at idle, I used power steering fluid but it doesn't really move. If I give it gas it will move so I set the sync in the cables so it moves equally but I'm not sure if my idle sync is close. Should I try an even lighter fluid? Water maybe?
I used the dead cylinder to set the initial sync and adjust my mix screws but wanted to try and dial the sync in more with the manometer. The fluid moves just fine when I give it more gas. Idle is currently set to about 1250 according to the stock jumpy tach needle
I have a set of 74 carbs so I did this to install some barbs http://www.650central.com/barb install.htm
Any ideas? I'm pretty positive there are no leaks in the lines going to the carbs from the manometer
