For Sale - Many Parts, Mid Michigan
grepper
fiddle futzer
Michigan
I'm also going to list these on eBay but will end the auction early is they sell here. PM your zip and I'll give you a shipping quote.
I have a 1977 xs650 Frame, no title. In Michigan it's real easy to get a title. $40.
I also have a box of electrical parts, relays, a single fire coil, some points plates. Let me know what you're looking for.
Parts...
Yamaha xs650 xs 650 Special 80-83 Single petcock Gas Fuel Tank
This tank is a little beat up with scratches and dents. If you're good with bondo, it could be a nice tank. The
Inside looks OK, some rust spots.
$5
Yamaha xs650 xs 650 Special 78-79 Dual petcock Gas Fuel Tank
This tank is a bit beat up. Several dents were filled with bondo. I started to strip it and was going to refill
the dents, but I found a better tank for my project. The badge mounts are gone; I was going to fill them. If you're good with bondo, it could be a nice tank. The inside looks good and clean.
$10
Honda 82 cb650 cb 650 air box with air filter. Usable condition.
$2
Yamaha xs650 xs 650 Special 80-83 right side air box part.
$1
Yamaha xs650 xs tx 650 Carburetor carb set.
I'm not sure what year these are. I do know they are the early BS38 carbs. One has the slide and diaphragm missing, the other, the slide doesn't move. I have not disassembled them, really only good for parts.
$15
Yamaha xs650 xs tx 650 1972 Carburetor car set.
These are the early BS38 carbs. Slides and diaphragms work as the should, I have not disassembled them. The bike did run when I disassembled it. With any carb set new or used, they should be cleaned, inspected and possibly rebuilt before use.
$25
Yamaha xs650 xs 650 Special 80-83 Single Gas Fuel Petcock.
Probably should be inspected and cleaned before use.
$5
Yamaha xs650 xs 650 Special 78-83 Gas Cap with key.
Chrome looks good and should polish up great.
$15
Yamaha xs650 xs 650 Special 78-83 Gas Cap no key.
Chrome looks good and should polish up great. The key barrel can be taken apart and pins removed to work with any xs650 key.
$10
Yamaha xs650 xs 650 Special 78-83 Gas Cap no key barrel.
Chrome looks good and should polish up great. This is just the body. If your cap is rusty and pitted you could easily put your key barrel in it.
$5
Yamaha xs650 xs ts 650 73 Gas Cap no key.
Chrome looks OK, see picture. Use for parts..
$5
Air Filters, 60 mm opening for Mikuni VM 36 and others.
Came with a set of Mikuni VM36 carbs I bought, but I went with nice K&Ns. Lost one of the clamps, but you can get these at any hardware or auto parts store.
$5
Yamaha xs650 xs tx 650 1972 Carburetor intake set.
They still look good. Yes, that's paint on there and can be washed off with solvent.
$5
Yamaha xs650 xs 650 Special 80-83 used Air filter
And engine back fire blew a hole in these. These are expensive new and I have replaced just the fome on these with carburetor foam from the auto parts store.
$5
Yamaha xs650 xs 650 Head light and ring.
OK shape, some scratches but in usable condition. Should fit any xs650.
$5
Yamaha xs650 xs 650 Speedometer Bezel.
OK shape, usable condition, should polish up good. Should fit any xs650.
$2
Yamaha xs650 xs 650 Fork Ears.
I think these came off an 1979 Special. They look to be in pretty good shape and should polish up nice.
$5
Yamaha xs650 xs 650 Turn Signal.
Good working shape, the lens looks cracked. Missing lens screws
$5
Good working shape, Post is bent, I think this could be bent straight again.
$5
Yamaha xs650 xs 650 Special 78-83 Front brake Master Cylinder
Should be cleaned and possibly rebuilt before used. Looks to be in good working shape.
$15
Yamaha xs650 xs 650 Special 77-83 Front break disk
No deep groves, should clean up and work great.
$15
Honda cb650 cb 650 80/81 brake Caliper.
Worked when pulled.
$5
Yamaha xs650 xs tx 650 1972 Front brake Master Cylinder
$10
Yamaha xs650 xs tx 650 1972 Front brake Caliper
$10
intersted in the keyed gas cap ,and the headlight and bezel . shipping to 08009 . let me total anf if want paypal payment . send me a pm and i'll get it out to you:thumbsup:
78-79 Special Dual petcock Gas Fuel Tank Sold
Thanks guys, thi is way better than paying all those fees with eBay.
I'll take the pod filters for $5 if they will fit a set of early BS38's. PM with payment info with shipping 84043. Thanks, Nick
The pod filters have 60 mm opening, too big for BS 38's. They are for Mikuni VM 36. I believe the BS38's are 52 mm.
If you will take a postal money order, I wan't whatever master cylinder you have left....shipped to 93245
I'll take the pod filters they will fit my carbs annill
Take One of the brake levers with master built in as long as one of them
Has brake light switch built in also
Similar threads
  • Price: $1750
  • Kitty hawk, North Carolina
Replies
6
Views
348
Sold / Found / Inactive - 72 XS650
  • Price: 6100.00 U.S.
  • Brandon MB.
Replies
1
Views
235
For Sale - XS2 FOR SALE
  • Price: 4950.00
  • Brandon Manitoba
Replies
10
Views
553
Sold / Found / Inactive - ON HOLD (1971 XS1B parting out)
  • Price: $5 - $400
  • world-wide shipping
Replies
3
Views
306
