Hi guys, looking for some guidance here. I’m rebuilding an XS650G that sat under a deck for 20 years. The carbs were pretty bad, so I bought the Mike’s performance carbs thinking it would be easier than completely refurbish the originals. Problem I have is connecting the 3 tubes coming out of each carb and also the size of the tubing. Peacock looks like it’s 1/4” and carbs look like they’re 1/8”. So I need to go from the Petcock in 1/4” and split into two to feed the two 1/8” inlets.
Have any of you guys fitted those carbs and how did you set them up? Also what Y or T piece did you use?
