Fred is right, i will clarify some points and add some info.
I will address the 34mm fork and some differences.
Hubs;.....All front wheel hubs from 73-79 Standards,........... and Special spoke wheel models...........79 Special II, 80G Special II and 81H Special II, can be used on your 76C front forks
All these are 36 spoke hubs and can be used on your bike.
Rims;.....73TXA front rim is Chrome on Steel and has a different profile to later 74-89 Standard Wheels............74TXA - 79F Standard rims should match your rear wheel rim, (if it is an original rim), these are commonly called mud/rain catchers and have a W style rim.
Special spoke rims are different to the 74-79 Standard rims.
Calipers;.............Caliper on the 76C was shifted to the rear of the forks, 73 to 75 had the caliper mounted on the front............Due to the caliper mounting change any 73-75 caliper can be used....... but..........
.the top mounting bolts on the caliper have to be swapped over to match the change from front mounted forks to a rear mounted fork.
So any 73 - 76 caliper can be used with the changes added to the 73-75 caliper as noted above.
Rotors;............Any rotor from 73-76 can be used on your 76C 34mm front forks.............any rotor from 77 and later
cannot be used with a 73-76 34mm fork. They have a different offset so cannot be used with the 34mm fork caliper. ............
Front forks;.............. changed to a 77-81 35mm, 36 spoke front fork set up.............. the 77-81 front Rotor will bolt onto any front 36 spoke hub, ..........from 73-81,............ if you change your front forks to a 77-81, 35mm setup.
73TX............................................74TXA.......................................75XSB
76C.............................................77D..........................................Special
