Jimbo W
If a mix screw o ring was bad would this result in a lean or a rich condition?
Still trying to get my '80 G running well on left cyl. Wet fouling of plug not solved after 3rd time of carbs off.
Float height @ 27mm, float valve appears to be working (shuts off fuel if floats moved manually), jets all original, squeaky clean in there, diaphram good, airbox original. Was running fine until I started fiddling.
Bit of smoke from left cyl when throttle is blipped so wondering if excess fuel has washed the bore. Compression test needed I think. Possibly should replace float valve o ring? Been squirting a bit of carb cleaner around so rubber could have been affected?
Another question: is the butterfly shaped bracket between the carbs needed? It helps to omit it while the carbs are going on & off regularly!
Many thanks, great forum.
