Pony
- Messages
- 27
- Reaction score
- 0
- Points
- 1
I would have posted this in my build thread but figured it would be more organized to start a new thread. Ill probably link this thread in my build for reference. I also used the search and came up with a lot of info but still have some questions, Ill try to make it as concise as possible.
What I have: Stock (as far as I know) 77' that is not locked up but not in running condition. The left side cylinde looks like it had some gnarly detonation going on and burned a hole in the piston. Right side cylinder had 30lbs compression. Valvetrain looks to be in good condition.
What I want out of this motor: I want it to pull strong and be able to get 100 mph out of it if I really twist on it, keeping it reliable and running pump gas. I am on a tight budget, but the motor is where I plan on spending the money. A budget, streetable, kick only, hotrod 650 (basically what everyone wants ha)
What my plans are: Split cases, rephase crank, bore the cylinder a step or 2, higher compression pistons, replace cam chain/guides, MrRiggs cam, pamco ignition, green monster coil, polish up the head, PMA charging unit.
Question #1: I have never ridden an xs650, am I wanting too much out of this motor for the mods I listed?
Question #2: I have not seen any photos showing a welded crank after it has been rephased. Is there a certain place/technique to doing this so the crank stays balanced?
Question #3 From what I have read with Hughs R&D the reliability concern with a rephase is with the valvetrain at high RMP's. Has leaving the stock valve springs in to allow them to "float" kept your motors from acheiving RPM's that will make it shit the bed or is it better run new springs and just keep it below 10,000 RPM's? Anything else I need to address with the rephase?
Question #4 For what I am looking to get out of this motor what is a recommended piston and compression ratio?
Question #5: How much should I step the bore up? The cylinders will clean up with one step, but will I need extra displacement to achieve my goal?
Question #6: Looking into a 78 and up transmission to use a Mikes 5th gear overdrive. I plan on making some trips pn this bike. With my tight budget, is this mod something that will make my life a lot better. Would try to keep this under 150$
I know that a lot of question and if ya'll could help me out with 1 or all of them it would be greatly appreciated. Thanks
