Ritchie the 79 model is the best model in my opinion....... probably because I have a 79 too
Now we know that your bike is standard and unmodified that should help a lot with diagnosing the problem.
It sounds to me like you are going to need to go through the whole bike systematically checking and testing everything because it is clear it was not running properly even before you cleaned the carbs "
Before I cleaned the carbs the engine was running a but rough"
If you have a good battery and the starter motor is working then that will turn the engine over quickly and should help you test-start the bike. If the battery is not holding a good charge then use a car battery with jump leads ,it will give your battery a big boost . You need a fully charged battery to generate a good strong spark.
Check your battery earth wire and clean the chassis connection. Make sure that you have a good strong spark to both cylinders before you mess with anything else.
The more things you fiddle with the more problems you can accidentally introduce . Just tackle one thing at a time. Fit some new spark plugs and remake the HT lead connections to the spark plug caps and coils .
Then you will need to check both your points gaps and test both the capacitors/condensors. Also check that the advance is moving freely and is not stuck
See if that improves your spark first.
