Dave Walters
Going to use this thread as a photo dump basically.
If you want to follow my build I post all these on instagram. My tag is daveXcore.
My plans for me bike:
King/Queen seat
Coffin Tank
Raked neck to 35 degrees to run a 6"-8" extended 34mm Front End with shaved and polished lowers.
David Bird Loop style hardtail 2 inch stretch and 2 inch drop
Single down tube from the neck to a small loop above the front motor mounts
19" heritage special 64 spoke front wheel (might lace this up to the mikesxs 21" hoop)
18" rear heritage special 48 spoke drum (lacing up to the 18" hoop sold by mikesxs)
Home built PMA with custom bracket and vf500 stator and rotor
Pamco Ignition using a green DYNA coil
When I picked it up
PMA swap:
Time for frame work and jigs:
Trimmed up the front:
Motor jig for when I cut the frame.
I slid my motor from the garage into my basement to work on it and clean it up:
Rectangle Head Light and Tail Light I plan to use:
King/Queen seat and fender:
King/Queen seat
Coffin Tank
When I picked it up
PMA swap:
